water is dripping down from the cooler
Hello everyone, I have the Samsung where the freezer is at the bottom With a large drawer that pulls in and out. So I have the problem also where water is dripping down from the cooler evaporator and it freezes causing the door to open and close very hard because the bottom of the door is rubbing on the ice. So uneasy way to remove the ice from the bottom is you take two bath towels and submerge them in hot water and ring out most of the water and put one of them out on top of the ice on the bottom of the freezer let them sit for a while. As the first is thawing out the ice you like in the second tall hot and ringing out most a lot of that one. Alternate the towels about four or five times and it will thaw the sheet of ice and the whole she device will slide out or you can break it in half to make it easier to get out. Let me know if this works for anyone it works great for me its really fast but I'm still working on finding out what causes this so it won't happen again but about every 2 to 3 weeks I have to do this. Let me know if it works for anybody,
この質問は役に立ちましたか?
2 件のコメント
I can see how your idea works with the dry Towel although it needs to have some time to melt the otherwise when you use the screwdriver to hit the ice it doesn't want to come loose from the plastic so either you leave the door open for a while to let that ice melt away from the plastic or you can use a hot towel and still use your screwdriver method as well using the wrong end of the screwdriver and hitting nice to crack it loose. Steve
Steven Forbes さんによる
It will break free easier if it is dry. When you tap the ice, cracks develop and the ice will come loose in big chunks. I lay a towel on the floor and slide the ice into the towel. There's no dripping water or mess.
LadyTech さんによる
