メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asusによって製造されれたラップトップコンピューターの解体と修理情報です。
Can my RAM be upgraded?
When I opened my asus q504u I did not see any ram slots? Is it built in to the motherboard? Several websites said that the ram is upgradeable.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
3 件のコメント
Just input what I am looking at with the cover off.
さんによる
I will pop it open again and try and get the numbers off of it. I will post an updated pic once I do so. Thank you for your input.
さんによる
Does anyone know how to open up the touch screen? i cant seem to find any information over this laptop anywhere.
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
How much RAM do you have installed?
According to the specifications for a Q504UA it is 12 GB DDR4 2133MHz SDRAM, up to 16 GB SDRAM.
This link from Crucial memory seems to indicate that 2GB, 4GB, 8GB and 16GB SODIMM modules are compatible with your laptop and that there are two (2) slots. Although you cannot exceed 16GB maximum.
http://www.crucial.com/usa/en/compatible....
You said that you had the laptop open. Did you check the motherboard under the keyboard to see if the RAM slots are there?
Update (12/11/2016)
Hi,
The following is all speculation on my part.
Looking at your picture, the only thing I think that I can see which may be RAM are the 4 ICs in a vertical row between the CPU and the fan.
If you Google the number that is printed on the IC it may be that they are a 'memory 'type IC (Nand flash perhaps since they all look the same). Hopefully if they are, then the number may also indicate the capacity. I cannot enlarge it enough to read what is written on them
Since there are 4 it could be that they are 4GB each and perhaps one of them is not being accessed by the BIOS if you have only 12GB working
I have searched online for pictures of identical replacement motherboards and they all show the same as yours. What you see as the green pcb is the entire motherboard so there is nothing extra under the 'black' which I think is the battery. There is also nothing under the HDD as there is no suitable external connection for RAM on the motherboard.
If the IC numbers indicate that they are not a 'memory' type of IC then there is the possibility that there are RAM slots on the underside of the motherboard. I could not find any reverse (underside) pictures of the motherboard to see what is there, so you would have to totally disconnect the motherboard and remove it to see what is underneath.
このアンサーは役に立ちましたか?
スコア 5
8 件のコメント:
I have the stock ram that came with it. I wish I could post a pic of it with the cover off. There is huge section that seems to be in a black cover. Not sure if that is where it's at. Or maybe under the hdd.
さんによる
さんによる
Thank you. I just added an image. Not sure where my RAM is. Maybe the image will give a better view of my problem.
さんによる
Did you ever find out? I'm sure you did, but for others, it's under the silvery rectangle on the right side. Pry it up gently the side tabs with forceps/ tiny needle nose pliers.
さんによる
Yes I did. It was under the silver plated. There was only one slot to use so I replaced the 4G with an 8 G and now I am running 16G. Not too shabby, plus upgrading to an SSD my laptop is flying as compared to before.
さんによる
3件以上のコメントを表示
コメントを追加
Under that plate between the heatsink and hard drive
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
S Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 38
今までの合計 11,971
