My screen is not working
When i switched on my laptop, the screen is malfunctioning as it splits into three different screen on the laptop. Is there a way to fix it myself?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@susu23 first you want to make sure that it is your LCD. Connect an external monitor and see what that shows. Should that show the same defect as your laptops LCD then you know that you are having a GPU (motherboard) issue. If the external shows a normal image, consider replacing your LCD. Take a look at this guide and this video. Combined you see how to remove and replace the LCD.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 702
