メインコンテンツにスキップ
2.3L 4cyl or 3.0L V6, 6th Generation
426回答 すべてを表示
2000 honda accord tail and dash lights not working.
#10 fuse is good on my 2000 honda accord. My son, while tinkering with front marker light, shocked himself. Now no dash lights, parking lights or tail lights. What is fastest solution to find problem.
2000 Honda accord
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
On my 20001 Honda accord my tail lights work but instrument lights don't
さんによる
コメントを追加
2件の回答
ベストアンサー
Kat, Recheck for blown 7.5 or10 amp fuse I think, in the passenger side door jam fuse box, may be marked tail/dash #10. Other fuses to check driver side dash fuse box: Fuse # 9 (7.5A), #10 (7.5A) , passenger side dash fuse box: Fuse # 10 (10A) ,under hood fuse/relay box: Fuse # 47 (20A), #49 (15A)
Good luck.
このアンサーは役に立ちましたか?
スコア 12
9 件のコメント:
Thank you so much. I had no idea there was a second fuse box on passenger side. Praise the Lord.
さんによる
Kat, Happy I was able to assist and thanks for replying back, so few do and it is nice to know when answer helps. Have a good day.
さんによる
First of all, forgive me, as I'm learning what I'm doing as I go. I have an 01 Accord, and my instrument cluster has no lights, and I have no back lights. However, my break lights, headlights, and blinkers work. I've replaced the multi switch, but the issue persist. The #9 fuse on the passenger side is labeled, "instrument panel/back up lights". Manual says 7.5 amp, but it has a 20 amp fuse in it. The fuse is good. I put a 7.5 amp fuse in it, but nothing changed. Any help/advice would be greatly appreciated.
さんによる
Hello Jason did you find out want the problem was? Having the same issue
さんによる
Hi, i changed fuse #10 on passenger side is labeled "small lights", an then , the lights on panel works again, but aproximately 15 min, the fuse breaks. I this moment I looking for the wiriing diagram, but i dont get good results. My car is honda accord 2000 standar
さんによる
4件以上のコメントを表示
コメントを追加
Thank you!!! You save me a big headache.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Does that go for 98 Honda Accord two I got no dashboard lights or interior or parking
さんによる
Never mind yeah there’s one on the passenger side of a 98 to
さんによる
L pfaff thank u so much!!!
さんによる
thank you my problem was fixed with the side panel fuse!!
i had taken it to a mechanic and was told it was the wiring in on off lights switch in the steering wheel.
thank you so much no more driving at night with hazard light on off i got caught in the dark
さんによる
コメントを追加
回答を追加する
Kat さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 87
今までの合計 42,327
