メインコンテンツにスキップ
How do I tighten the loose band hinge or change the band?
I have a Klipsch GiG speaker. This is what it looks like:
There is a band around the speaker. Supposedly it is removable, because Klipsch promotes color bands like these as an optional accessory:
The problem is, the hinge of the band became loose over time. There's a screw that loosened and can become completely unscrewed if I turn enough. I can screw it back by turning the other way but it remains very loose. I cannot tighten it. I cannot make the speaker stand because of the loose hinge.
Supposedly, the band should be clip-on. I even found a picture which demonstrates the band that has been snapped out.
The problem is, no matter what I try, I cannot actually "snap" the band out, like how it is snapped out in the picture above. The snap-button is so very tight you probably need a powerful machine. I can only unscrew the screw part.
How can I fix this loosened hinge? I don't actually have a colored band to change to. I just have the black band and I want to tighten the screw. I thought by snapping the female part of the screw out, I could tighten it onto the band and then snap the band back into the speaker. But I'm not able to do that because of how incredibly tight the button is.
Rant: This I feel is a total design fail in the part of Klipsch. The speaker is otherwise great with amazing sound. Why did they miss out on making a proper hinge that doesn't loosen over time?
PS: I looked everywhere for a tutorial guide or video showing how to fix the screw or how to change the band. I can't find anything in this mighty internet! I really hope you guys can help me :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hello, @adtc
This could mean the the screw hole is 'striped' which can be fixed but it would mean re-drilling a new whole.
If you have any questions feel free to comment.
Thanks,
Keegan
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No, sorry, it's not stripped. Do you have this speaker device? I know you're making a general assumption about screw threads, but in this case the screw wouldn't tighten because after a certain point of loosely screwing on, the screw just spins freely inside the band. There's no way to put a screwdriver on its head unless I tear open the band destroying it. The question is very specific to the Klipsch GiG device's unique construction.
さんによる
コメントを追加
I had dame prpblem and coming loose. Then i saw on photo that the connection is ment to be a button. So with the band off I put a small screw in the socket and pulled, pulling gently to "pop" out the socket. Then screwed that end back on the band as it was suppost to and pop the whole band back together on the GiG speaker.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
[image|1141271]
[image|1141272]
さんによる
コメントを追加
回答を追加する
ADTC さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 547
