leak in the refrigeration system
A leak in the refrigeration system on an LG model number LFX 28978ST.
If you really have a refrigerant leak, you will most likely not be able to repair it yourself. I had that problem in my SubZero. The tech came out and put a new evaporator unit in the refrigerator part, then evacuated and recharged the system. All that required some specialized tools and knowledge.
So, what, exactly, are your symptoms?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 89
Ashanti,
Do you have a refrigerant leak?
LadyTech さんによる
We need a little more information. Did you diagnose the leak? Are you making the repairs?
LadyTech さんによる
