メインコンテンツにスキップ
モデル番号はA1199で2、4もしくは8GB容量
How to repair a hold button which does not hold?
The hold button on the device is completely ineffective. That is, it does not lock out the ipod buttons when engaged. What can be done?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Compress the top bezel a bit with your fingers (maybe hold the ipod in one hand
but with the fingers at the top and bottom, instead of on the sides). Try to
operate the Hold button. Does it work? If not, you may need to pop off the top
bezel (it is held in with a mild adhesive - see the Step-by-Step Guides for
pictures and tools) and check that there is no glue/dirt/muck on the contacts.
If you do the removal carefully, there should still be enough glue on the bottom of the bezel, so you should be able to push the bezel back in and the
glue strip should hold it in place. Try the hold button again. If that does
not work, I don't know what else could be wrong.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
tyler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 4,513
