メインコンテンツにスキップ
家庭用電話の修理ならびに解体ガイド。
496回答 すべてを表示
How can I stop crackling noise on Astra landline phone
Astra Whitehall 1212 landline phone has developed a crackling noise after being dropped on the floor, I think it was just the handset that got bashed. The phone line is ok when another phone is plugged in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Unfortunately it sounds like you probably broke a connection in the handset, or maybe the circuit board. Very difficult to find and fix.
If you are into it, take the case apart and look carefully under high magnification at everything inside for visible signs of damage. Take the battery out first.
If you are even more into it, get a can of freeze spray and a heat gun and shoot the freeze spray at various parts of the circuits inside and see if you can get it to make the noise. Also heat it (carefully!) with the heat gun (or hair dryer) and listen for the noise. Using this technique you might be able to find the area that has been damaged. Then look very closely and see if you can find it.
Thing is, once you have found it, you will have to do some micro surgery to fix it. What, exactly, that is, depends on the nature of the damage. You might have to glue the board back together, and resolder joints that were broken.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
A Davies さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 47
