メインコンテンツにスキップ
This HP laptop was released in 2014 and is pre-installed with Windows 8.1.
Why is my screen black and unresponsive
Hello,
So recently after not being on my laptop for roughly a week, i decided to go turn it back on to do some work. But it didnt... The screen stayed black and all i got was power to the keyboard and the caps lock button flashing at 3 second intervals. Consistently, Like it will do that for hours. Ive drained the capacitors restarted it, and nothing. What happened ? I havent dropped it or anything. Ive taken it apart. Re-seated everything... Help ! Im thinking it may be in a boot cycle but i dont know....
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Please someone help
さんによる
How many times does it flash, if it were doing it in a repeated sequence?
さんによる
@brittkwa just 1 flash, then the long wait (Probable not 3 seconds) but a long pause then another single solid flash and that's it. It will continue that cycle consistently until power is removed
さんによる
@brittkwa i went and tried that, (Applies paste too) and still noting
さんによる
コメントを追加
1 件の回答
ベストアンサー
If it's just 1 flash of the caps lock light, it needs the CPU reseated or replaced. You mentioned reseating everything, so it looks like the CPU is faulty.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jarrod May さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 345
