I keep getting error code P0534 in a LR2 Land Rover.
I keep getting error code P0534 in a LR2 Land Rover. It's a 2010, 3.2L Engine. How do I fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This is a code for the air conditioning one of the following, AC leak, wiring, AC refrigerant pressure sensor. so this means either your coolant level is down to an unsafe level to operate or theres an issue with the wiring to the sensor or the sensor itself is bad. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 129
