What are the yellow items on the camera board of the Surface Pro 3
Just wondering if anyone knows what the "yellow" items are on the board which houses the cameras in the surface pro 3 are? I've attached a pick.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Looks like they are antennas for the wifi/bluetooth
このアンサーは役に立ちましたか?
I thought this as well, but I can still connect to the wifi at home even those these have been torn (courtesy of removing a cracked screen and all the gunk that goes with it). Havent tried bluetooth connectivity yet though.
Opened up a few of these for screen replacements.
The only way they get torn is if you pried against them when you could've just slid between the adhesive which is what I always do now same for iPads.
Even if these are partially torn, it doesn't affect the signal strength unless a whole section is removed, which is why it still works fine :)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 84
