Where is the wifi chip on my Galaxy tab S 8.4 wifi?
The Wifi is broken (switch greyed out, won't turn on). I believe the chip has failed and am looking to replace it. Do I need a new main board?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@alstein it is under an EMI shield. See attached image
The IC itself is a BCM4354KKUBG
Unless you have the ability and the tools to reball this IC you may consider a new board, a reflow or send the board of to someone to repair it for you. Replacement motherboards are available at places like this.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 20
今までの合計 4,290
1件のコメント
@alstein post some pictures of your motherboard with your question so that we can point the IC out to you. For that use this guide iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
