My battery drained, and it doesnt charge again
what is the BEST REMEDY for my cellphone SAMSUNG GALAXY J1, it suddenly turned off and when i charged it, it doesnt charge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
irene0047, Try the reset procedure form the tips and tricks guide link below. Make sure charger is working or try another good known working charger. If no luck replace battery. Links 2 and 3 are how to replace battery and where to purchase. You can also search for lower priced battery. Good luck.
Samsung Galaxy J1 Tips & Tricks
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 165
1件のコメント
Even though it appeared 'dead', I put it on charge overnight and the next day held the 'ON' switch down for about 5 seconds before it gave a little buzz and came up with the display showing the outline of a green battery (half full). I left it on charge a few more hours then switched it on and it worked.
independent さんによる
