メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
NikonのD3200は、24.2メガピクセルのデジタル一眼レフカメラです。このモデルは、高度な仕様と性能を備え、カジュアルな写真愛好家向けに設計されています。2012年発売。
Why can't I use all focus lenghts
Hello,
if I set my camera (Nikon D3200) to manual mode an try to play with the kit zoom lens (Nikon 18-55mm VR II ) then I can only turn the focus to a range between 24-35 mm and I can't get a sharp image even when I try to turn the small wheel . So is my lens broken or is there something with my camera?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
I was advised that the motor in the lense is possibly kinda worn out and replacing the lense should help.Keep the body.it also has some kinda knocks and sort of intermittently sticks a bit at the 55mm end this was attributed to an overtight full lense rubberised cap being pulled on and off.They are delicate.Who knows?but its almost certainly lense based rather than body.
さんによる
コメントを追加
3件の回答
Check if the Lens Macro Switch it locked.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
No it's not locked. There is A switch for VR mode and another A|M switch which I think is for auto or manual focus. But there is no switch for macro
さんによる
by small wheel you must mean the viewfinder focus
さんによる
The 18-55 mm kit lense doesnt have a VR.
さんによる
at least not on my 2012 + kit supplied one. Will a replacment lense featuring VR work on a non VR original fitting?
さんによる
コメントを追加
are you saying that the lens will not zoom past the 35mm mark so that you can not set the lens to a focal length between 35mm and 55mm, if that is the case then it is likely a blockage in the lens, the lens will need taking apart and cleaning, this will usually solve this problem, you'll have to search youtube for a guide on how to do this. Kit lenses are not the best glass to start with and to be honest I wouldn't hesitate in give it a go yourself, if you a serious or even a hobby photographer you'll be looking to move away from the kit lens and buy some better lenses, you can get some very good used lenses.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Me too .
My 10 year old D3200 progressively started to skip shots and lock ons on auto focus. The shop advised using it manually but exactly like above anything after
35-55m is a blur everything before sharp.
Yes its a kit.
Should it ALL be sharp at evfry focal length in manual then?
さんによる
コメントを追加
if the lens works in auto mode, then you may have an internal lens issue. the lens motor/gear assembly must completely disengage when you use the manual mode. what may have happened is the internal parts may not be moving completely or have been partly damaged from a lens strike or even a sudden partial switch from one mode to another. any sticking, ratcheting sounds or noise from a lens is bad news, as they are designed to act smooth.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah sounds more like it
さんによる
コメントを追加
回答を追加する
Albertos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 1,126
