メインコンテンツにスキップ
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
32回答 すべてを表示
Why is my car not starting and showing code 89
My 2012 chevrolet cruze is giving problem to start as if my battery if flat bt all the lights and hooter are working properly.When i turn the key the alternator turns a little bit and gives me code 89.When i jump start the car it starts without any problem.my battery was serviced and the car could start atleast 4 times after that but then it started with the problem the next day
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
I also have similar problem.
Error code 89, sound is loud.
What could be the problem?
さんによる
Yes, similar the noice of the engine become in side the sound system...through the speakers.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi,
Check the output from the alternator.
Use a DMM (Digital Multimeter _ Voltmeter function) and connect it across the battery terminals with the engine running, (Be careful when you do this as the engine is running!)
The Voltmeter should read between 13.8-14.4V DC. If it is less than 13.8V DC then the alternator is not charging the battery and it will slowly go flat.
If this is the case take your car to an auto electrician to get the alternator checked.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This some how related to the steeeing lock, shutdown the car and press the start button without break (or open the contact if its not with a keyless start) and then unlock the steering then move a lttle left or right the start the car it will start normaly.. If it works dont ask me why coz I dont know, I just discover this solution by myself
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thermostat issues
さんによる
コメントを追加
回答を追加する
Joseph cafu さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 95
今までの合計 46,017
