メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
Why does my MacBook Pro shutdown when the battery is between 50-30%?
My MacBook Pro 13" 2009 Unibody shuts down randomly. I purchased it from a friend. I noticed the battery needed to be serviced and the body below the keyboard would get hot, so I got a new one installed at a local Mac repair shop. New battery is great, low cycle count. Heat issue was better. It even charges up to 100% percent no problem. But when it is off the charger and goes down to say below 50% it will automatically shutdown. I plug the magsafe back in and it boots up. Sometimes I do notice it can get down to below 20% and then shut down. What do you guys think? A battery or logic board problem? Thank you in advance for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Had a similar issue when unplugged at 55%. It was fixed by resetting with:
https://apple.stackexchange.com/question...
Take anything you read with a grain of salt.
さんによる
コメントを追加
2件の回答
ベストアンサー
@boogiexl ,Eddie. Checked a couple forums and found this, Link 1,2 You can try a battery calibration or Link 3 Reset Mac SMC (System Management Controller) use this reset when experiencing power management and battery problems: Mac isn’t turning on, sleep isn’t working, random shutdowns and reboots, battery isn’t charging, Good luck.
http://www.makeuseof.com/tag/calibrate-m...
http://www.tomsguide.com/faq/id-2349626/...
http://osxdaily.com/2010/03/24/when-and-...
https://support.apple.com/en-ca/HT201295
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As stated above, try a SMC Reset. If there is no change. Try reinstalling your OS and Verifying all Updates are applied. If issues still occur, have an Apple store or service provider run a MRI test, there is chance that the battery is not below the FFC % yet still causing shutdown like failure.
Good Luck,
Henri
Lead Service Technician
MacSuperStore, Santa Barbara
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eddie Bugayong Jr さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 9
今までの合計 18,817
