Why washer goes to "ol"during wash/rinse spin
elite,model 110.28032701, after wash no water in tub,clothes still wet,and code"ol"on display
この質問は役に立ちましたか?
この質問は役に立ちましたか?
See my previous answer on this:
このアンサーは役に立ちましたか?
this answer is for a maytag washer,my question was for a kenmore
It's the same answer. OL is an overload code.
@eddie9115 just checked your washers manual and "oL" still stands for overload. With your washer this could be caused by a bad bearing in the outer tub, a bad control board as well as a bad motor sensor. Check to see if you can ran the diagnostics mode and see what it tells you. Let us know. Kenmore 110 Diagnostics
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 574
