メインコンテンツにスキップ
初代モデルのiPhoneです。モデル番号はA1203で容量は4, 8,もしくは16 GBから選べます。アルミニウム製の背面ケースです。開口にはかなりのこじ開けるための力が必要です。そして半田付けも若干必要です。
224回答 すべてを表示
No voices, just sound while listening to music
Hi!
When I listen to music with my iPhone i just hear the sound. There are voices but very quiet. It's not the fault of the earphones, I changed them. And I can't remember any accident or something to be the reason for this..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
which iphone do you have?
さんによる
It's the 2G..
さんによる
コメントを追加
2件の回答
ベストアンサー
If you normally keep it in your pocket, I suggest checking the jack for lint buildup. I have an iPhone 3G, myself, and once I got the lint out (straightened paperclip and compressed air), the problems went away! It's so simple, I had kicked myself for never thinking of it as it had been bugging me for months!
It's really amazing to think that there was so much lint in there that it was pushing the plug out of alignment...but there it was.
If this, by chance, doesn't solve the problem, it may be a short or fault in the jack or it's wiring. However, that's rather unlikely. The i-series mobile devices, regardless of generation, are pretty solidly built.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Good answer.
さんによる
コメントを追加
i thinks its the earphones actually because i had the same problem....they have to be a certain size for the iphone or youll have that problem....
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No it's not their fault.. I've got the original Apple earphones and with my iPod, they work without any problems. Then I tried other earphones which fit into the iPhone, but there are the same problems again..
さんによる
コメントを追加
回答を追加する
Svenja さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 14,209
