メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5S top-left corner heating up while screen is on
Dear all,
My iPhone 5S, when the screen is on (i.e., when I'm using it) the top-left corner over heats!! it really gets warm, of course the battery is consumed faster due to this. The whole screen doesn't heat up, only this small part out of the LCD itself.
The screen is broken into 5 big peaces (but in the bottom of the phone, away from the top) but still working.
I have seen some disassemblies videos and looks like only the small vibrating motor is there.
I have to replace the screen anyway, but, does anyone know if this problem is due to the broken screen or something inside the phone?
Many thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
The only thing of note in the top-left corner is the vibrator. If I read your question properly, this overheating started occurring after you cracked your screen.
Two things could be happening here:
  1. The vibrator is shorted and drawing lots of current, hence the excess heat and battery drain.
  2. The vibrator is fine but the contact pads underneath, that make electrical contact, are shorted and hence the excess heat and battery drain. This could have been caused by the impact that cracked your screen.
I would open the phone, following this guide very carefully (and gently) and remove the vibrator. Look for obvious debris or anything else that is amiss. The flex cable may also be damaged. Then see if your phone works normally (minus the vibrate function). If so, then order a new vibrator.
iPhone 5 Audio Control and Power Button Cableの画像
製品
iPhone 5/5s/SE (1st Gen) Vibratorの画像
製品
$11.99
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hi Minho!
many thanks for your answer!
In fact I friend of mine gave me this phone already in this condition, so I don't know when it started to heat up. It heats up only when the screen is on, i.e., when I'm using it. It doesn't matter if the vibrator is running or not.
But your answer does make a lot of sense. Actually I will buy the screen replacement and change it.
Perhaps I can try tomorrow to open it and check the terminals for the vibrator :)
As soon I get any news, I will post it here!
Thanks a lot
さんによる
コメントを追加
回答を追加する
luciano caldas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,433
