Differences between 2 cars
What is the difference between Eighth Generation 2001 and a 2002 Toyota Corolla S and is it possible to do a body transfer between the two? Preferably 2002 to 2001
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@sirsteel , Alex, I believe the bodies are the same, if engine/transmission different you may have to swap computers and harnessess. Below is a link to interchange list pdf. Good luck.
このアンサーは役に立ちましたか?
Yes the body parts are interchangeable. Its all a complete bolt on applicaiton.
このアンサーは役に立ちましたか?
By the way, if you are going with the Carib kit there are some a little adjustment on the fitting.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 339
