Why does it turns on then cuts off
Hi, the ps4 pro logo shows then requests that I turn it off. Then goes off.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
このアンサーは役に立ちましたか?
I have the same problem but it wont boot so I can aply no update
このアンサーは役に立ちましたか?
Usually this is an issue with the APU easiest fix is to replace the motherboard. Outside of that though you could try to reball the APU solder points but this is difficult even with the right tools and if you do it wrong you have not other choice but to get a new motherboard
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,144
