メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
iPhone 5c won't charge past 3%
My iPhone 5c won't charge and the charger is brand new but after I plugged it into my moms Dodge Journey USB port my phone stoped charging , now it dies and turns back on but doesn't charge past 3% and the lighting bolt doesn't pop up , does it need a new battery ? Help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The iPhone charging subsystem can be damaged by non-MFi (Made for iDevice) certified chargers. Based on the sequence of events you describe, this is what happened to your phone. Cheap dollar-store charging bricks also can cause this.
While it is possible that your battery is defective, I believe that the Tristar(U2) IC on your device was damaged by the USB port. This is not a DIY repair unless you have experience in micro-soldering.
If you have access to a known-good battery, you can always replace it. If a known-good battery does not charge, then it is a U2 problem.
iPhone 5cのバッテリーの交換
The 5C also suffers from micro-fractures on the logic board so this could also be the root problem on your device. A qualified repair shop that does micro-soldering should be able to troubleshoot your device properly if you don't want to do it yourself.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shadiamond さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 3,882
