My phone doesnt open.
I cant turn on my phone. Whenenever I plug it to the charger it only blinks, i tried to reboot it but the logo doesnt appear
your phone shouldn't open. It should stay shut.
but to get it to turn on, put it into recovery mode, and then from the menu, hit reboot,
if it doesn't even get to recovery mode, you've got a dead battery. replace it.
このアンサーは役に立ちましたか?
hi i tink there is no minimum voltage in your mobile battery... try to boost your battery or change the battery it will work..
minimum voltage in battery is 3.6 below the 3.6 volt phone not turn on
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 217
did u try to remove your battery,sim and put back again?
hendriyo さんによる
yes, i tried
Adorablelight 06 さんによる
