does not poke coffe pod
can I get my Kurig coffee maker repaired........it doesn't poke the pod for the water to go through the pod......... feels like it might be bent ???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@esmills__16 if it is truly bend you can replace the needle assembly (depending on your model). Every now and then you can find the parts at places like this. On this guide in step 9 you see two small Philips head screws on the left hand side (above and below the water inlet). Those hold the needle assembly to the top part. Remove those to remove the assembly. Again, take lots of pictures and post those with your question by using this guide.
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
My experience is some pods have a harder plastic type covering rather than a thinner foil type.
It looks like the bottom needle that punctures the bottom of the coffee pods has come out of the assemble. Can I put it back in or do I need to get a whole assemble replacement?
このアンサーは役に立ちましたか?
I took the bottom assembly out, but I didn't see a needle. It no longer makes a hole at the bottom. What can I do?
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 61
過去 30 日: 243
今までの合計 27,272
7 件のコメント
@esmills__16 can you post some images of the puncture needle? Use this guide iFixitでの質問に画像を追加する方法 for that. What exact model is your Keurig?
oldturkey03 さんによる
no photos but he took it apart and back together again....and it is working.....thank you so much for your help........Ellen.
Ellen Sergas さんによる
I am new to this site, but i am trying to figure out why the exit puncture needle is not poking a hole through the bottom of my coffee pod that i put in?
tammymartin16 さんによる
I am having the same problem!
Jolene さんによる
I'm having the same problem. So I improvised and punctured a whole at the bottom and it works.
Ericka Barrett さんによる
2件以上のコメントを表示
