The Akai Professional MPC2000XL MIDI Production Center combines a 64-Track MIDI Sequencer and a 32-voice Stereo Digital Sampler, with 16 velocity and pressure sensitive rubber pads.
Hi, Have you tried reinstalling the old RAM and the configuration that you had and see if it works properly again? What configuration did you have before? Was there anything in SIMM Slot 2?
It might not work properly but remove both RAM modules and see if it goes OK on the 'fixed' internal 2GB RAM. This might prove whether it is an removable RAM module problem or a motherboard problem
jayeff さんによる
I used slot 1 and I have 2:mpc so switch the rams it started working fine then it got stuck and started triping im using zip drives
polok6940 さんによる
Hi, Have you tried swapping them back? Why did you swap them in the first place?
jayeff さんによる
I swapped them just to see if it worked and it did at first but then it c started tripping again
polok6940 さんによる
Hi,
jayeff さんによる
