How to remove manual transmition from my 2wd toyota pick up
i need instructions on how to remove the manual tranny from my 1991 2wd toyota pick up
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@bennythe1 ,Ben, your local library probably has the repair manual for your 1991 Toyota pickup which would be nice to have on hand, or try using the links below to see how transmission removed for clutch change to see what you are in for. The 3rd link says it is a downloadable zip file for your repair manual(I did not try, try at your own discretion),Good luck.
https://www.youtube.com/watch?v=B9JU931G...
このアンサーは役に立ちましたか?
Can I have workshop manual for manual transmission pn133 Toyota Hilux Vigo
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 15
今までの合計 2,021
