メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
iPhone often restarts after battery replacement!
After battery replacement, iPhone while is power on, touch stop responds and in 1-2 minutes device restarts. Restarts keep happens and while is in standby. The problem is not appeared in specific time after boot up.
I tried 3 different new batteries and the problem still apears!
I tried also to reinstall the old battery and the problem disappeared!
I dont know what to do...
With the new battery I have better battery life but device keep restarting which is very annoying...
With the old battery I have no restarts but it needs charging every 3-4 hours!
Anybody can helps?
Device: iPhone 4S iOS 7.1.2. noJB
PS: I have to higlight that I changed the battery 2 more times in the past whithout any problem...what happens now???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check to make sure the new battery has the same APN number as the old battery. I remember when doing battery repairs for this model, we thought we received a bad batch of batteries (all were not working, or causing restarting issues), but it was an issue where some phones would act strange unless it had a specific APN number or the same APN number as the original.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I still believe it's a bad batch of batteries. I gave up doing iPhone 4S battery replacements. I've been getting too much refurbished, aftermarket or used batteries.
さんによる
Could be, stopped doing phone repairs last year. I do remember we did get a batch in from China of a certain APN number (we requested this, after a couple of shipments were completely non-working) and 95% were working, other than the couple of obviously faulty ones.
I think they were original batteries, slightly used, but no difference in capacity from the original. We found it difficult to get more beyond this due to the age, and just gave up with the 4S'
さんによる
The old one has APN: 616-0579 and the new that I tried to install were two 616-0579 and one 616-0581 (I have returned the other 2 so I cant find the number now)...
さんによる
In that case, it sounds like it could be bad batteries, as @benjamen50 said. The device is quite old now, so it will be difficult to source good ones, but try looking for a genuine new/slightly used battery
さんによる
コメントを追加
回答を追加する
Agnostos さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 366
