メインコンテンツにスキップ
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
How do I disable the onboard RAM on an iBook?
Hi! I've got an iBook G3 that is giving me kernel panics, and I'm 99.9% sure it's due to bad onboard memory. This specific machine aside, does anyone know how to disable onboard RAM on an iBook G3/G4? I once saw a guide to cutting the paths to the RAM on the logic board, but that seems a little extreme, and I'm wondering if there's an easier and more effective method, perhaps a command line command I can enter?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi, here's a URL on how to do that--make sure you scan down to get to what you need. Good luck. Ralph
http://osxbook.com/book/bonus/ancient/wh...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Actually I read the document, and while it's got good info, it doesn't discuss disabling onboard iBook RAM. Does anyone know how to do this? Thanks
さんによる
Could you find the installed memory address and use the procedure listed to temporarily shut it off? Ralph
さんによる
コメントを追加
回答を追加する
rdklinc さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,460
