Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
このアンサーは役に立ちましたか?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
過去 24時間: 3
過去 7 日: 18
過去 30 日: 46
今までの合計 15,466
1件のコメント
Make sure bearing is assembled properly just behind steering wheel
p_buchwald さんによる
