メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Display backlighting went out once...now back again
Hello ifixit,
Today as I was working something happened. I had turned the display brightness to 100% for about 5 mins or so when the light suddenly went out.
I tried to connect an external monitor and it was working. Then I took a flashlight and pointed it directly to the display.I found that the display is OK, but the lights were still out. The Apple logo on the lid was off as well. I was very upset and I left it like that wondering what could be done and was gone for about 10 mins or so. When I came back , lo and behold ... the light had come back on .
However, now I fear that it might happen again! So what do you think, what could be the problem, the inverter board or the display CCFL?
I stay in India, hence if I have to order for a component, and if it is not the faulty one, chances are less that I would get to return it back and order the correct component.
So please help me, ifixit ... I know you are the only one who actually could do so ...
Many thanks in advance,
Nirmalya .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Since you could see the desktop with a flashlight, I would suspect the inverter board. You might want to keep one on hand in case it goes out under load again. Here's the fast method for fixing it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Here's the part: MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlightの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
good answer +
さんによる
コメントを追加
回答を追加する
Nirmalya Bhattacharya さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 1,641
