Why wont my disc draw stay closed
My disc draw keeps ejecting
It sounds like you have a calibration bug with the light sensor that controls the eject button. Try turning off all the lights in the room, and attempt to insert a disc again. If it is the light sensor, you should be able to insert and eject a game without it repeatedly ejecting. Let me know what happens, and we will go from there.
Note; Make sure you start with the system off, before you turn off the lights in the room.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 50
Is the eject key stuck in or sticky, causing the internal key to stick?
Ben さんによる
