How do I find Top dead center
I need to know how to find Top dead center on an 88 GMC. does anyone know how? Do i have to have a timing light?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If your just looking for TDC you do not need a timing light . first you need to find the number one cylinder then remove the spark plug . Turn the engine by hand (use a socket and bar on the crank shaft ) until you have compression stroke . You can tell by putting your finger over the hole and feeling the air push against it . Once you have the compression stroke look on the crank pulley , there will be a mark to indicate TDC. align this mark with the timing mark , usually just off to the side of the pulley with makings on it. This video should help
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 34
過去 30 日: 176
今までの合計 17,696
