メインコンテンツにスキップ
The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
13回答 すべてを表示
締切られた回答
How to replace/fix a power button
I am in the market for a Droid 2 and I have found that is in prefect working order minus the power button. It will not turn the device on. The device has to plugged in to power on and then it works fine. All of the apps and features are good to go then. Any advise
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If the physical connector on the frame is not damaged, then find another power button. If it is damaged, replace the frame (this will require much more work, and you should look at the guides for removing the LCD and digitizer). A droid 1 frame should work and you can get one cheap from a water damaged phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 6,097
