メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
My A1181 just started displaying "overscan", parts of image missing.
I've got a modestly old MacBook A1181, the model that had a dozen siblings with slightly different features but shared the same designation.
Overnight, without any fuss or muss, the display went into an "overscan" mode. In other words, the image on the actual screen is only about 80 percent of the full picture and
about 20 pct is "off the edges" (numbers nominal).
I can still bring them up by sliding the window, so to speak, around, but that's very unfriendly
Any ideas how to reset this? I tried a bunch of tricks, including reinitializing the PRAM [a]. No good.
Thanks muchly.
[a] rebooting while holding down command-option-P-R
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You could actually try to go to the service centre. They will usually know about the problem and can help you fix the laptop. This method needs a little bit of cash.
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
@ctaneshaa you are the service center on here. If you do not have a solution or a valid answer, consider not to answer.
さんによる
コメントを追加
回答を追加する
ifix2009 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 45
