メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
Booting and Restoring issue (RSOD)
Let's not make this a wall of text, it's quite simple.
I received a iPhone 5s. It would not boot.
Water Damaged
I began curing the iPhone in a ultrasonic cleaner with 91% isopropyl achohole, wiping corrosion with a gentle brush.
It booted! But as time progresses I realized that it booted to a redscreen, fading to black.
Figuring it was a software or firmware issue, I booted it to DFU. Whilst attempting to restore I get the error 4013. Simultaneously seeing the Redscreen on the iPhone.
(IMPORTANT)
It's a bummer. I have microsoldering and heating gun's at my disposal. Along with replacement chips.
  • BOOTS TO DFU
  • BOOTS TO APPLE LOGO
  • RED SCREEN APPEARS AFTER APPLE LOGO
  • I had the camera flex detached.
  • Restore attempted. (Error 4013)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I have the exact same problem, except the phone is not water damaged. I've tried everything I could think of. Disconnecting the sensor flex, camera & digi & restore, new battery (this happened to the phone a few weeks after I had replaced the battery in it), new LCD & restore, new charge flex & restore, tried DR. Fone iOS system recovery... Nothing is working. Still keep getting error 4013. Anyone have any ideas as to what is causing this?
さんによる
Also, I have noticed that the phone sometimes produces a high frequency squealing sound when it is plugged in.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Any hot spots on the phone? Very likely a short caused by a blown component. Can you remove the shields? Inspect the components under as close magnification you can get. Look for blacked or cracked components. Look near any Hotspots on the phone. Remove the component and attempt to replace if possible.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Okay, any micro soldering items on the cheap I can get?
さんによる
Have you tried another charging port dock assembly? The one in there may be damaged from liquid / corrosion.
さんによる
Yes I had tried
さんによる
コメントを追加
回答を追加する
Hammer Deals さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 614
