メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
20回答 すべてを表示
Unresponsive screen and black lines
Hey,
My 5s was connected to the computer when we had a power cut. first the screen had some black lines and now the screen has 2 black patches and the screen doesn't respond to touches. where do you think is the issue and what parts should i buy? I'm trying to fix it myself (first time)
regards,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Either the screen needs to be replaced or you have a board level issue which is pretty much as bad as it gets.
さんによる
コメントを追加
1 件の回答
If you have someone call your phone, does it still vibrate/ring? Or does your computer recognize it when you plug it in through USB? If so, then you'll probably just need to replace the screen assembly.
Find an LCD/Digitizer assembly for the 5S, iFixit sells good quality ones (the cheap ones can cause major problems and in my opinion are a waste of money). I doubt the power outage caused it, as it sounds like the LCD is damaged. Black lines and splotches are typical of a physically damaged LCD.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sachith senanayake さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
