メインコンテンツにスキップ
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
23回答 すべてを表示
Can Toyota Diagnose Transmission error Code P 2757 without tear down?
I have a 2010 Toyota Corolla LE 70,000 miles.... Can the Toyota dealership, or Transmission shop diagnose the actual problem with error code P2757 related to the Torque Converter Clutch Pressure Control Solenoid Circuit Performance Stuck off reading. The dealership said they needed to tear the transmission apart to find problem. I do not believe them. I have been told by other mechanics that their computer testing equipment should be able to detect which solenoid is out. can a single solenoid be replaced if it can be detected? Please help and advise.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I can say with 100% confidence this problem can be diagnosed without transmission removal and teardown! The answer to your question__can a single solenoid be replaced?__YES! I am not sure if I am allowed to give my name and phone number on here so I will check back for a reply to my comment.
Good Luck,
Buck & Dennis
さんによる
I have the same problem with my 2010 toyota voxy....... i would love to get it fixed
さんによる
コメントを追加
7件の回答
ベストアンサー
@michaelangelo nobody on here can answer this question with any kind of certainty. This will totally depend on the dealers capabilities. My suggestion is that you find a different dealer. You stated that you "do not believe them" so go somewhere else for a second or third opinion.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you for addressing the question, but I would like to know if anybody has fixed or dealt with the error code P2757 for Toyota Corolla 2010. what is the process for identifying which solenoid valve is possibly bad, or the wiring, or harness, etc. does it really require an expensive tear down to determine any of the above?
さんによる
If you do an extensive search you will find there are plenty of bad stories about this. I'd stick with having a dealership at least taking a look at it. Check this out "P2757 TCC stuck on is a mechanical problem w/ the torque convertor clutch system. Mechanical meaning the torque convertor, SLU solenoid, any of the TCC or pressure regulator valves inside of the valve body or a poor circulating transmission cooler system will. Any of these issues will trip this code. If you want it fixed then take it to a competent A/T technician. " from here
さんによる
I have a Lexus IS250 2007 with this error code. With mine its the sixth speed solenoid thats faulty because when I drive it as a manual and don't select 6th gear then I wont get the error code.
さんによる
コメントを追加
最も参考になった回答
@michaelangelo , Michael, If vehicle out of warranty, skip the dealership and find a good local professional transmission repair shop, as they are probably more familiar fixing this problem then some of dealerships. In a lot of cases the dealer ship actually does not fix the transmissions in house, all they do is remove and send out for repair and then reinstall after transmission shop did repair. Have a good transmission shop take a look, diagnose and estimate repair. Good luck.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Sir base on my experience as toyota technician i agree to teardown your transmision.we have same cases here after we open the rear side of transmision cover we have found that overdrive clutch and plates is burned out and even we replace the said shift solenoid valve and worn out disc and plates but still you cam feel the sudden shiftshock.so we decided to make overhaul ..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
No post since 2016. Waste of time to say it is solved. If this is solved then so is The Middle Eastern Crisis!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
have a 2006 lexus GS300 same F problem…replaced solenoid , did nothing…lexus sucks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a 2007 IS250 and it will come up with this fault. I just keep resetting it. But I notice that if I drive it in Sports mode and don’t use 6th speed it never faults.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check ur fluid for &&^& sake!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
They are a sealed for life unit. You don't change the fluid and they don't leak.
さんによる
コメントを追加
回答を追加する
Michael Angelo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 92
今までの合計 21,917
