メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The 7th generation Honda Accord, from 2003-2007.
ignition switch electric problem
my honda accord wont start just makes 1 click noise. if i turn the key to 2nd position then try to start it sometimes it starts and sometimes i have to jiggle the key between these 2 positions to get it to start what could the prpoblem be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Did you ever receive an answe or diagnosis, mine is doing the same thing currently. And as the previous responder recommended I have tried all those operations and they are OK
さんによる
コメントを追加
4件の回答
ベストアンサー
@lupejjsb ,Lupe, If battery is good and starter is good and you find your self having to wiggle the key when turning ignition to start the engine, I would suspect the ignition is worn and needs replaced. There have been various recalls on Honda's ignitions for various reasons and may be worth checking into. I will post a link below for Honda recall sight and how to change your ignition switch. Good luck.
http://recalls.owners.honda.com/service-...
https://www.youtube.com/watch?v=FlR5CqxP...
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Try to put it on neutral not park and then turn on the key, if it start that’s mean its the neutral safety sensor has issue. If it didn’t start, the need to replace the ignition switch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Common Honda Accord Starter Problem:
1. Dead or Weak battery
2. Poor electrical connections at battery terminals
3. Park or Clutch Switch is Broken or Misadjusted
4. Security System Error
5. Damaged Starter
6. Fuel Delivery Problem
7. Spark Issue
If your vehicle fails to start don't just let it sit, as the problem may only get worse. Hope this can help you check your car and know what you can do.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just tried it shift it to neutral it did start one click
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lupe Borden さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 43
過去 30 日: 144
今までの合計 56,273
