メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
No engine light on dash
having problem engine light will not turn on with key on have two of the same trucks one does the other does not and i cant read the codes
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
miz4getful, See Brandon B. and oldturkeys answers above or Re POST year, make, model,engine, transmission and complete question so we, here at ifixit can answer your question effectively.
さんによる
@lpfaff1 really? Another Canuck! Well, greetings from an expat.
さんによる
Thanks for the greeting oldturkey03, all the leaves are down, you know what comes next, have a great day.
さんによる
コメントを追加
1 件の回答
ベストアンサー
miz4getful, check the bulb for missing/loose/burnt out(exchange it for a known good working one and check the instrument cluster back side for damage, burn mark,corrosion, solder joint break, etc. and if OB2 port is not working check your cigarette lighter fuse for being blown. Good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
miz4getful さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 120
