Dust in camera lens
There is a spec of dust in my rear-facing camera - everything else is fine. Should I get a new camera replacement or will blowing a can of compressed air once I'm in do the trick?
この質問は役に立ちましたか?
before replacing the entire camera try opening the camera and cleaning between the lens and the lens cover. I recently had a s5 that had an unusual blue tint to the photos it took when I bought a new camera for it. took it apart it turned out to be the protective cover was never removed from the lens at the factory . So maybe the dust is just between the lens and the glass cover on the case. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 345
