replacement battery contact is different
I've tried two replacement batteries. The batteries fit and screws in ok, but, the contacts on both [including an ifixit] replacements are slightly different and don't make contact.
there is a iphone 4 , iphone 4 (CDMA) and iphone 4S. the iphone 4/4(cdma) have the same battery and the iphone 4s has its own battery. make sure you have the right battery for the device you are working on.
このアンサーは役に立ちましたか?
The model number on the back of the phone corresponds to 4s and the ifixit replacement says 4s. But, I might try looking at a 4 battery and seeing if the contact is what I need.
Thanks for the response. It might put me on track.
glad too help. let us know if you get it working.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 54
1件のコメント
the Iphone 4s CDMA battery is the same as that of the iPhone 4.
4s CDMA batter is different from the Normal 4s... so you can use the Iphone 4 battery for Iphone 4s CDMA..
Abdul Galib さんによる
