メインコンテンツにスキップ
Released September 2016, the Vivo 5R represents the sixth generation of the Vivo series and an update to the Vivo 5.
How do I get out of guest mode?
I somehow went into guest mode, but I can't find a prompt under security settings to turn off guest mode.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 36
17 件のコメント
Oh I'm so thank you
さんによる
miranda5749, please assist me here...i some how fail to get the proper apk file site....so how do i download it
さんによる
Plz help me .... I have same problem entered in guest mode unable to come.out ofit
さんによる
I am having the same issues
さんによる
theres no guest mode checkbox for me in setting would you mind helping me?
さんによる
12件以上のコメントを表示
コメントを追加
6件の回答
最も参考になった回答
Qs: how to come out of guest mode on BLU 5R?
Answer:
Option 1) We need to contact BLU and they would probably share an APP that we need to install that solves the problem.
OR
Option 2) I have done that work for you...
Check out my blog to see the solution and also find a link to download the APK that BLU shared.
このアンサーは役に立ちましたか?
スコア 18
24 件のコメント:
hey how do i install the apk to my phone?
さんによる
yes thank you it worked
さんによる
Thnk u so so much
さんによる
OMG...... I'm so happy I'm out of guest mode...Thnx so so much...Well Appreciated
さんによる
Wowww.... at last i get back all my call history and fotos... Thanks you very much.
さんによる
19件以上のコメントを表示
コメントを追加
It's in Settings>Security>Guest mode
just un-check the box! It's not obvious and took me an embarrassingly long time to figure out what that weird icon was
このアンサーは役に立ちましたか?
スコア 8
9 件のコメント:
Can you add a screenshot?
さんによる
My settings haven't guest mode
さんによる
There is no such thing in my settings.
さんによる
there is no Guest Mode option in Security on my Blu Vivo 5R.
さんによる
4件以上のコメントを表示
コメントを追加
Hi everyone,
Quick and easy fix. All you need to do is download and install this .apk file (search 'stewbanga') Disable Guest Mode Blu Vivo 5R and you will be good to go. No factory reset, nor reboot required.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You get in to guest mode by using a 3 finger swipe up to unlock the phone. I suspect that a 3 finger swipe up or swipe down will get you out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi everyone i have the perfect way to exit guest mode or get in, all u need to do is to download apk that controll this mode it called: GuestModeDoctor.apk
U need to google it and install and it will work, i have vivo r5 and it worked!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have tryed this several times and it just won't give me the option.
I used it a while ago and worked fine.
When I open the APK app, just shows me info about my phone I don't need? Can u help me after I open the APK app, what happens next?
さんによる
コメントを追加
Ok so I had this problem too.
I went to settings at at the bottom clicked on “about device”
Then click wireless update, and waited for 30 minutes whilst it installed 70 updates.
After that I went it to settings at at the top the it is!! Guest mode uncheck and it's all back to normal, albeit with a few updates…
Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
miranda5749 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 30
今までの合計 32,510
