メインコンテンツにスキップ
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202回答 すべてを表示
HTC One M8 top speaker
Hi guys. Is there any other reason besides faulty top ear piece speaker, that there is no sound from the top speaker ? I did screen replacement with the full screen housing and I transferred old earpiece from the old housing and there is no sound, obviously I ordered new earpiece to fix this but I'm just wondering if there is possibility that I damaged something else that new earpiece might not work as well ? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
You sure you didn't just accidentally installed the earpiece speaker upside down?
When transferring the old earpiece speaker from the old housing, did the part separate to the point where the coil was exposed in the earpiece speaker?
さんによる
I mean, I'm still waiting for the new speaker. And no I din't put the old speaker upside down, the contacts were touching the daughter board the right way and the piece didn't look much damaged, the coil wasn't exposed.
さんによる
コメントを追加
1 件の回答
Problem solved, it was the earpiece.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Miroslaw Turon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 630
