メインコンテンツにスキップ
The C700 is a budget PC notebook released in 2008 by the Hewlett-Packard Company, or HP, through its Compaq subsidiary.
6回答 すべてを表示
Question 1:  Why does my laptop keep shutting down?
While using my laptop it continues to shut down mid use. Why is this happening?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Student Question
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The most likely reason for your laptop to shut down mid-use is that the cooling fan has built up debris in it, causing it to be unable to cool the device. This makes your laptop overheat and turn off. I would recommend using canned air to blow out the vents leading to the fan. These are located on the side and bottom of the laptop. If the issues persists, you can open the device up and check to see if there is debris build up in the fan or if it requires replacement. To get to the fan to clean or replace it, follow the instructions in this guide.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rob Yule さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 154
