メインコンテンツにスキップ
The HP Envy 15 x360 is a laptop-tablet hybrid that can be identified by the model number 15-Uxxxxx.
My computer only works while the charger is pluged in.
I can only get my computer to work if I have it plugged in. Do I need to replace the battery?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 37
27 件のコメント
My hp labtop is still shutting off after I unplugged it
さんによる
Its "laptop". Not labtop.
さんによる
@colemanrobert956 Mine is doing the same thing idk how to fix it
さんによる
same here! mine is doing the same thing only NOW the battery percentage is going down 1% per day. when unplugged it powers down right away. I assumed it was the battery. I dont even know how much a battery costs. if they are $50 like a cell phone i am SCREWED!!
さんによる
New battery in my ASU’s laptop but still only works on mains help please
さんによる
22件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Yes you will need to replace the battery. Since you are able to use your laptop when it is plugged-in, it is a great indicator that your charger adapter is not the issue. Make absolutely sure your computer is turned off. Remove the back cover of the laptop by unscrewing the screws and gently lifting the cover up. Locate the battery which is usually a relatively large rectangular shape device and replace it with a known working one. If this does not work, there might be an issue with the actual wires inside the laptop. If that is the case you will need to either send it back or see if a local electronic store can do something with it.
このアンサーは役に立ちましたか?
スコア 30
7 件のコメント:
It's not turning on when pugged in
さんによる
Thank you so much Sam- this seems to have worked. Battery was new supposedly “non” removable but where there’s a will….
さんによる
Even though battery is replaced with new one still issue persisting.
さんによる
Can anyone help me with the solution, do the needful
さんによる
my laptop is working only when i plugged in supply, and i bought a new charger even though my laptop is working only when i plugged in
さんによる
2件以上のコメントを表示
コメントを追加
最も参考になった回答
Before you decide to give up on your battery and get a new one, there might be a chance that you finished using up every last ounce of energy in your battery and it didn't get time to charge again :)
Your laptop generally tries to charge the battery + run on power when it's connected to a power adapter. What's happening now is, the battery is not getting charged (actually, it's not getting detected) and your laptop thinks there's no battery and is simply running on power.
A new battery will of course have some charge and your laptop will be very happy with it and keeping charging it.
This is the 3rd time I'm writing this instruction today:
> Remove the battery and kill the static energy in your laptop by holding down the power button for 20 seconds.
> With the battery still removed, plug in the adapter and turn on the power.
> Your laptop starts working now.
> Now here's the tricky part - Insert the battery 'after' you've powered on the laptop. Now your laptop will detect the battery and start charging it.
Hope this helps! :)
このアンサーは役に立ちましたか?
スコア 33
37 件のコメント:
Thank you genius!
さんによる
I have the same problem but the battery is not removable how can this be fixed? Can u please send me an email to get the answer asap thank u dlrs1009@yahoo.com.mx
さんによる
Works like a charm
さんによる
I really hope it works, giving it a try now. Thanks.
さんによる
I Tried but it still showing the charger is plugged in but not charging
さんによる
32件以上のコメントを表示
コメントを追加
That would be the best guess. It is possible that there is another board failure preventing the battery from receiving the charge but a bad batter is the most likely failure here.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Whenever I plug my laptop it displays battery 100% and the moment I unplug it shows battery low and go off.
さんによる
コメントを追加
Hi i would recommend getting a new battery or try taking the battery out and putting in back in again
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Hi, My laptop shows an alert message to change the battery. But I'm in a situation where I cannot go to the service center now. How long will I be able to use the laptop without battery? In a only plugged-in mode? Now my laptop works only when connected to power supply.
Is it healthy to use it that way?
さんによる
コメントを追加
Hi @mrfleming07,
Assuming that you have Win 10 installed, create a Win 10 battery report just to check that the new battery is OK first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Replaced the battery and did everything suggested. Problem was fixed not by putting a new battery, nor inserting it while plugged and all that. I had to do a hot re-set on Windows losing many settings and programs. Problem solved? Yes, but today after a week working fine, it started doing the same thing!! Digging into this, I suspect a Windows update. When resetting windows, it tries to download updates, and one of these screws the battery issue, as reported by somebody on another forum. Asus techs have no idea why or what to do. A bummer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
In my case. I just replaced with a new battery. I let the battery charge to 100%… yes, the battery was able to chargeall the way with the power cord connected. BUT. I still need the power cord connected to turn onn the laptop. It will not turn on with just the battery connected. ??????
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
your case same with mine, my laptop still need power cord to turn on. how your laptop now ,any solutions
さんによる
My laptop has a problem as it it turned on when connected with power supply and when it turned on it can be used after removing supply. Can any one help me to fix this problem
さんによる
Have a HP 17z-cs000 and it is also only booting up with power cord plugged in, then once booted up it runs fine on battery without power cord. I am getting a CMOS Checksum error when it boots but have not had issues with date or time being incorrect. Not sure what steps to take next...may try resetting CMOS to factory and see if that helps...other than that ???? no idea!
さんによる
Joanne Johnson i have same problem, did you find any solution? Please let me know
さんによる
コメントを追加
回答を追加する
James さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 34
過去 30 日: 115
今までの合計 208,471
