メインコンテンツにスキップ
Dell laptop from the 11z series released in 2009. The Inspiron 11z-1121 has an 11.6-inch screen and weighs 3 pounds.
3回答 すべてを表示
laptop key "B" came off
my "B" key came loose. I'd like to know why this might this happened or how to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Sometimes a key will pop off if the computer has been dropped or something was blocking the key, causing it to come off. To fix this problem, look at the back of the key and make sure the hinges are in tact. If not, you need to get a replacement for the hinge. If the hinges are in good shape then try to line up the corresponding parts of the hinge to the key, press down firmly and try wobbling the key until it snaps into place. For a more detailed guide look at the troubleshooting guide for this device.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jerativat Satayarekha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 99
