Why will the A button not work when I press it?
I press the A button in a game that uses it and it will not work. How can I fix this?
The button was dirty underneath so I removed it, cleaned it with rubbing alcohol and repaired it.
このアンサーは役に立ちましたか?
The A button may not work because the connection from the A button to the motherboard may be interrupted. I suggest you check out our button replacement guide.
このアンサーは役に立ちましたか?
It's possible that there is something lodged beneath the button that is causing these problems. Opening up the controller and cleaning beneath the problematic button may solve this issue.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 9
今までの合計 139
Andrew Gonsalves さんによる
