Why is my ultranav not working?
The ultranav cursor does not respond or move when trying to use ultranav..
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If you are running Win 10 have you checked that you have the latest Ultranav drivers installed?
Here is a link to the download page for the driver for your laptop. In the component selection box (half way down the page, select Mouse and Keyboard. In the Operating System box next to it select Win 10 32 bit. Click on the download link for the UltraNav driver.
このアンサーは役に立ちましたか?
If you are having issues with you Ultranav first verify that it is enabled. To do this go to Device Manager, right-click on the properties under Ultranav driver, and then check the status of the device, if disabled, change to enable Ultranav. However, if your Ultranav is not installed check the following link to install it: http://support.lenovo.com/us/en/download.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 12
今までの合計 6,158
