メインコンテンツにスキップ
Repair information and troubleshooting for the HP Compaq Presario C700. This is a budget laptop made in 2008 as part of the Compaq Presario series of notebook computers.
22回答 すべてを表示
I have a Grey Screen and it does nothing
My laptop has a grey screen. I went to a privately owned computer repair store and the guy told me that I would have to leave it with him for 2 months. That's a little sneaky. I also asked my friend who gave me the laptop and he said the problem might very well be the hard drive. but I just want to make sure. It's a good machine, it turns on fine, the only concern in the grey screen. I want to try to fix it on my own but I would need some help from someone. Hope somebody reads this and they can tell me EXACTLY what to do.
Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There are several things that can cause this issue. lets start with the easiest first . Static discharge. to fix this remove the battery and the power cable so the machine has no way of powering on then hold the power button down for 60 seconds then release it and put the battery back in and plug it in then reboot. If this gives no joy try connecting the laptop to an external monitor via the vga port on the side of the computer. If again you experience no Joy open the back panel that holds the memory and remove one dimm of mem try to boot again with just one dimm .repeat and reboot with the other dim in this will tell you if you have one bad stick of memory . If you still have no joy after all this then the problem could be in the GPU compaq had issue of heat causing the solder to break and loosing connection . If this is the case then we can try to reflow the solder on the board but this is a last resort . Try the other ideas first. Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ron Starkman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 2,938
