メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年秋に発売されたLGの大型スマートフォン。LG G3(D855)はQuad HD IPSディスプレイと1300万画素カメラを誇る。
screen flickering and turns black at high temperature
Hello as my title states my lg g3 is broken. When i start using my phone for about a minute and the screen starts flickering and then goes black screen. Its weird because my phone keeps running until i turn it off. What could it be hardware or firmware or screen>
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi,
When the screen blacks out try shining a torch at an angle close to the screen to see if there is still a display there. You may have to look very closely to see it.
If you can see the display then there is a problem with the backlighting which may mean that there is either a loose cable connection from the systemboard to the LCD screen or a faulty LCD screen.
If there is no display at all then there is either a loose cable connection from the systemboard to the LCD screen or a faulty LCD screen.
If you turn on the phone and suspend the display timeout feature and then just leave it there without touching it, does the display still disappear?
If not then holding the phone or movement is causing the problem, again pointing to a loose connection.
If it still disappears then again it can either be a loose connection or a faulty screen.
Here is a link to the Ifixit guide on how to replace the screen in your phone.
LG G3 スクリーンアセンブリの交換
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
You just saved me buying a new phone. For anyone reading this who can benefit from my experience; phone was damaged and appeared to have black screen. Shone a light at an angle and the screen was very faintly visible. I turned the brightness up fully and the phone is working. Anything less than full brightness and the screen appears black and unuseable.
さんによる
コメントを追加
Perhaps not only at high temperature, right?
I think this is the "screen flicker fades darkness" problem described for example here: https://www.youtube.com/watch?v=7j88SysX... and here http://forums.androidcentral.com/lg-g3/5... and here https://www.youtube.com/watch?v=gAUkXLR7... , https://www.youtube.com/watch?v=qdg6t_I0...
I tried some of the workarounds and worked fine for some days. I haven't tried the 'bake the motherboard' option, because I don't have any way to verify the oven's temperature is in the proper range
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
DONT bake your motherboard!
i posted some important infos for y below
さんによる
コメントを追加
https://forum.xda-developers.com/lg-g3/g...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
valazquezm12 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 11
今までの合計 4,173
